Got a problem with my washer dryer, steam coming out of the soap draw when it’s on the dry cycle. took the lid off and I assume that the condenser is the white plastic bit on the righthand side back of the drum, this does have water trickling through it but not all the time, I assume its programed to trickle a few seconds every minute? should there be a trickle though the soap draw too
yes it will cycle on and off through the condenser, yes you can also get a trickle thorugh then drawer, and yes you will get some steam from the drawer during a long dry cycle, steam rises and has no-where else to go, as long as its drying the same as before leave alone, if the drying is not so good now the condenser may just be partially blocked with fluff
