I went to this machine yesterday. I haven’t seen many of these but the PCB was blown due to water leak. The water appears to be coming from the dryer fan chamber, on the top of the chamber is a stub which is open and you can see the fan impellor if you shine a light down the hole. There are traces of water coming from this stub; my question is should there be a hose connected to it as a drain or if not why should there be water coming from it?
Thanks, Ray.
