Indesit WD12X – Door interlock problem.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WD12X – Door interlock problem.
  • #20659
    jrrl152
    Thank you for the reply P45 to my last post “Indesit WD12X Broken Door Catch Door Stuck Pls Help!!!”. I have today recieved my new parts from UK Whitegoods and the door interlock has a different plug on it to connect back into the machine. They both still have 3 pins on but didn’t want to guess which pin is which. I only need to put 3 electrical spade adapters on but in which order. Please help. The new interlock was supplied from Masterpart Part no 011140 and has three pins marked from the lock end (LH) as pin 2 then 1 then 3. The old interlock has pins 2, 3 then 4 marked on again from the (LH) lock side. Any ideas!
    #187895
    Dave_Conway
    Re: Indesit WD12X – Door interlock problem.
    Sorted over the phone 🙂
    For future readers, there are two types of interlock (and quite a lot of the other parts) on this model, the serial number will be required to obtain the correct one quite often 😉
