Indesit Wd12x Noise??
  • #23325
    wynny
    Hi Guy’s,
    You helped me once and I hope you can do it again. My Indesit WD12x washer dryer has suddenly got very noisy, basically when its doing anything! I have checked in the drum for coins and around the rubber seal etc and can see nothing. The drum turns by hand freely without any noise but when its starts to spin / wash etc there seems to be a horrible noise coming from the front of the machine just below the door although the machine keeps working and no funny smells or smoke etc.
    Any ideas?
    Thx
    #197753
    Re: Indesit Wd12x Noise??
    Concrete weight working loose?
    Power off if investigating…….
    wynny
    Hi, Nope the concrete looks intact. Had a closer listen and it gets louder the faster it goes, it sould like its between the drum and somthing?
    #197755
    wynny
    Ok, Update. Just had the back off it (power off of course) and if I spin the drum fast by hand I get the noise. AND, there is play in the drum so I think the bearings are going!
    Its an integrated machine so I would prob have to either repair or replace with the same type I guess.
    #197756
    wynny wrote:there is play in the drum so I think the bearings are going!
    Replacing the drum bearings and water seal is an option although a lasting success rate is usually just a few months. Because the main drum shaft is the main reason for the failure in the first place and unless that shaft is replaced you will have a reoccurence soon enough. Sadly the drum shaft is not available as a replacement part as it forms part of a complete sealed drum assembly costing over £100. The cost therefore is grossly uneconomical in the extreme. 😥
    So as I see it, it’s bodge in a new bearing kit and hope it works for a while, or dump the whole machine and buy something decent! 😉
    #197757
    wynny
    Looks like its scrap! so where’s the best place to find a good price on an integrated machine as Im selling the house and dont want to put a £500 machine in for somone to enjoy!
    p.s NOT Indesit
    #197758
    If your moving soon then best get bearings fitted as being the cheaper and more convenient option?
    #197759
    wynny
    Ok,
    1. Where can I get the bearing kit from (part no, price etc)
    2. Is there a fitting guide anywhere so I can bodge it myself?
    Thx
