Indesit WD12x Replacement bearings
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WD12x Replacement bearings
  • #23389
    wynny
    Can anyone help with where I can get a replacement bearing set from pls for the above washing machine.
    From my previous topic, its clear I need to replace the bearings and need some help to find the correct part and also the best way to replace them. If a guide is avaialble then great!
    Thx
    #197964
    Dave_Conway
    Re: Indesit WD12x Replacement bearings
    You need to check the bearing housing (spider) on this model, there are two types, one is lightweight aluminium and the other cast iron.
    To complicate matters further, the more common aluminium type has two shaft sizes (measured at the drum pulley end), one is 22mm and the other 26mm.
    Having said that, by far the most common is the aluminium 26mm version, if it is this is the kit you need:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=514
    If not, please let us know and we can dig deeper 😉
