Hi guys.
I have the above fault. I have tested motor, elements, thermisters, solonoids,pump and everything is ok. Should I replace the module or have I missed anything please.
Thank you
have found on these machine the slightest fault to earth sends the timer into a spin
i usually disconnect earth to machine ( obviously dont touch metal work we do so hate to lose members ) switch machine on and try if it does not spin you can reconnect earth to see if its still spinning if it is scrap it usually motor causes it
If error code F8 don’t forget to check pressure switch, preferably by substitution. Burnt but still functional contacts seem able to cause this fault.
Mike.
