Indesit WD12XUK
  • #25005
    Jonah
    Hi all,
    Really need some help with this one, switch on washer door locks ok the washer then fills and pumps at the same time and timer turns around with the door lock inicator light flashing, have changed the PCB and put a new EEPROM in the PCB but still no good, the new EEPROM seems to push fit into a slot but the slot is smaller than the EEPROM is this correct?
    Have not seen to many of these so any info would be appreciated, have checked the part numbers and they are correct for PCB and EEPROM.
    cheers
    Slot normaly… I did not understood why did you changed PCB and EEprom…. Read error from flashing light (door lock): serries of XX flashes…
    Isn’t necessary to be PCB or Eeprom fault…
    #204203
    Flyman
    Re: Indesit WD12XUK
    Filling and emptying at the same time is normally an NTC fault. The machine does not know if it is full of hot water so it does a continuous flush through for safety. 🙂
    #204204
    Jonah
    Re: Indesit WD12XUK
    Thanks for the help lads, dont normally touch the low end stuff but its good client for us, will try your suggestions.
    cheers
