Indesit WD12XUK
  • #29952
    clivejameson
    We’ve been supplied a drum/tub part number C00080661 but it has two outlets at the base instead of one…can anyone confirm this is the correct part number or if it’s a packing fault please?
    Serial 511298068
    #225306
    Re: Indesit WD12XUK
    Outer drum is listed as a C00094280. It also mentions a ‘Subs Kit’ C00094097 which apparently has a bung for one hole and a few other bits & bobs.
    The part number you have given comes up as ‘Part not found’ on Partfinder. 😕
    clivejameson
    Re: Indesit WD12XUK
    Thanks Jim
    Typical eh?…the part number I quoted was from M’part and Connect recognised it too 😕
    I’ll order the subs kit and see what arrives….on closer inspection, the new tub has four outlets instead of two (one for the disp hose, one for the sump hose). I can’t find a pic or description of the kit but luckily we quoted big time to do this one so we shouldn’t lose out 😉
    Thanks again
    Clive
    #225308
    Re: Indesit WD12XUK
    Subs kit contains two bungs, door seal, door seal clamp and a hose clip.
    Masterpart have been sending out Indesit damper pegs with their own label on top of the Indesit one as a substitute for WMA 1603347 pegs. I have fitted two sets and one has come adrift already. The distance between the locking barb and the shoulder of the peg on the Indesit one compared to the correct one is a very critical three or four millemetres, you really have to hammer it home and even then it is touch and go to see if it locks out. Not oging to use anymore unless the 1603347 is superceded, still getting them from elswhere ATM.
    clivejameson
    Re: Indesit WD12XUK
    That’ll do nicely! :tup:
