This has a F15 fault, I removed coins ect from pump, tested on cycle worked ok before leaving. customer tells me when it goes into a spin cycle it cuts out after a while, shows F15, if she resets to spin only again stops halfway again.
any pointers please. john
Where does F15 relate to a pump fault? Its a dryer heater relay fault. F15 has been used for dryer relay fault from the start, even for the clicking dial machines.
