Indesit WDE12- First error F-01, now error F-02!!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WDE12- First error F-01, now error F-02!!
  • #16140
    sprout
    Started this morning, I was getting error F-01 about halfway through the wash. Opened it up (power off of course!!) gave all the connections a pressing home, including one at the bottom of the drum at the rear, on either a tacho or a low water sensor (i dont know which, but it was hanging out!)
    Power on, fault cleared, almost got all the way through a wash, and now i have fault F-02!! It only seems to come up when the machine is gearing up for a big spin, in fact i just watched the machine try 3 times to ramp up to full speed, fail each time, then F-02 popped up.
    Fir information, the motor seems to be working ok so far as every other function goes, and doesnt seem to be getting particularly hot
    #167677
    Dave_Conway
    Re: Indesit WDE12- First error F-01, now error F-02!!
    F02 is a motor related fault so whatever had fallen off (sounds like the motor plug me given the fault) may not be back on correctly ?
    It may also have been the temperature sensor connector, these are a common problem.
    #167678
    sprout
    Checked all the connections again, everything seems tight and pressed home, so I have booked Indesit for a service call (94 quid!!)
    Will let you know what they find.
    #167679
    Goatboy
    sprout wrote:…so I have booked Indesit for a service call (94 quid!!)
    :eeek:
    Unless your in a certain area of London, Repairs@ could have help you out! 🙁
