Our lass is complaining that our washer drier isn’t drying anymore.
It’s getting warm, it turns..
It seems normal only clothes come out wetter.
If it makes any differance the machine has laid idle for 12 months or so.
It seems normal in operation, just doesn’t dry!
Hi Charlie
Have you ckecked to see if the machine has a drain-out filter….if this is blocked it would stop the machine draining the condensate away (plus the cold water spray let into the condenser)
The other possibility is the fan motor isn’t actually running…especially if the machine has been stored unused for a length of time….this would require an engineer to sort out of course
Clive
Righty-oh where do I find the filter? and the Fan?
Im a mechanic by trade and fairly handy, I’ve stuck a pump on it in the past..
Just want to try to get an idea of what’s involved before I pull it in pieces!
