indesit WDG 1295 WG
  • #11692
    simonb
    indesit washer dryer WDG1295WG s/n 801233952 requires double cold valve (one of for trickle for dryer unit) none in stock local does anyone know if i can use a different valve alternative maybe qualtex as local supplier has all qualtex valves in stock.
    simonb
    #146278
    Dave_Conway
    Re: indesit WDG 1295 WG
    Genuine part number according to PF is C00056339 it’s only about £14 retail, so I would go for the gen one I think to be on the safe side 😉
    #146279
    Errrr! Why not just fit a common or garden double valve and simply change over the flow restrictor?
    Easy :tup:
    #146280
    Dave_Conway
    Martin wrote:garden double valve
    Is that one of those that lets you sprinkle the lawn and top up your pool at the same time Martin ?
