indesit wdg1295wg (no high spin)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries indesit wdg1295wg (no high spin)
  • #13904
    deltra
    hi all, this machine works ok till it gets to the final high spin! the speed buildsup to max stays there for 15secs,then back down to slow speed.then builds up and does the same. does this about 6 times then spin cycle(7) finishes.fitted new module, motor seems to be ok.any ideas would be appreciated
    #157125
    Re: indesit wdg1295wg (no high spin)
    Probably the timer.
    #157126
    bobokines
    I’ve had several indesit/aristons with old type timers that have this symptom. It is the timer at fault although the sympton appears as if it the module or motor
    Bob
    #157127
    Tubs
    Timer :tup:
    Changed lots of these for same fault, usually module for no wash action, timer for no spin.
    #157128
    deltra
    cheers guys, thanks for your answers, but thankfully the lady has seen sense and is going to buy a new one.(pity she could’nt wait till january for an ise machine. 😀 )
