Indesit WDG985W drain pump.
Home Forums Public Support Forums Spare Parts Help Indesit WDG985W drain pump.
  • #29644
    scosystems
    Hi All,
    I am having a problem with my Indesit. Have finally traced the fault to be the drain pump, I am now finding it a problem to obtain a new one.
    I have checked your online shop, but it does not mention my model.
    On the pump label there is the following;
    COD. 7402/55879 240V 50HZ 90W.
    And on the side “PLASET spa ITALY”.
    Help!
    #223969
    Re: Indesit WDG985W drain pump.
    Hiya,
    There’s lots of them that fit a wide range of machines, often alternatives as well but for a definitive answer if you drop Dave a line on spares@ukwhitegoods.co.uk he’ll advise the one you need with a price etc.
    helo_75
    if its a water cooled pump, u’ll probably be able to change just the pump rear, by undoing the screws, that makes it a lot easier, as most manufacturers use the same base
    #223971
    Pump to fit your machine is part number C00043725. An email to spares@ukwhitegoods.co.uk for prices and ordering.
    scosystems
    Thanks for all the replies.
    Just one problem though – when I try to email spares@ukwhitegoods.co.uk, it bounces back saying the email address does not exist ?
    RCPT TO failed: Requested action not taken: mailbox unavailable
    #223973
    That’s very strange, there’s mail received fine on that account just moments ago.
    I’ll try it now and alert Dave to the thread, he should post an answer soon enough, possibly in the morning if not later.
    scosystems
    Just re-tried the email – it now seems to have gone though! go figure!
    Many thanks for all you help.
    Simon 😀
    #223975
    Dave_Conway
    The serial number is required also please, C00043725 is used before 80118….. there is a different pump after that date (Jan 1998)
    #223976
    scosystems
    Just to say thanks to all here (esp Dave), I have now managed to order my new drain pump from your web site.
    Many thanks to all.
    Simon. 😀
