Indesit WE 12 Washer
  • #5762
    Lost user manual – no water coming through into machine hence doesn’t start. Found an abundance of small items in the pump chamber, keys, coins, screws……now removed. All electrical connections seem fine just not working. Any help gretaly appreciated.
    #113552
    Re: Indesit WE 12 Washer
    Fats,
    Just make sure you have cleared all blockages from the pump OK 😆
    Then set the dial to the black ‘spot’ (there are several positions with the same)….Press and HOLD the ‘Start’ button for several seconds until the light starts flashing rapidly 😉
    Then, try a spin only cycle?….It should pump and spin as normal, hopefully ❓
    Let us know otherwise OK?
    Martin, not sure the previous message got through.
    Anyway thanks for the reply – not sure what you mean by black spots.
    Actually managed to get it to work for a rinse cycle but its gone again and can’t repeat what I did last time. From a display point of view everything looks as though its going, i.e. the time counts down, unfortunately its not though.
    Fats
    #113554
    Anonymous wrote:Anyway thanks for the reply – not sure what you mean by black spots.
    Fats,
    Sorry I forgot that your machine had a Programme Display panel. I which case no wonder your confused as I was talking about another model . 😳
    You have checked the pump and cleared it out, fine. Have you fully ‘reset’ the programme I wonder, check user guide on that. Also it is not filling or at least erratic, could be a water inlet valve playing up? Really stuck for ideas on this otherwise without and engineer checking it out, nothing more I could advise.
    lotusray
    almost certainly a module problem iam affraid (its counting cycle down and doing nothing )
    #113556
    News update!
    Fats (David) has bought a new machine!!
    What a surprise eh 😉
