Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit WE 16 UK Door Seal replacement
- This topic has 6 replies, 3 voices, and was last updated 21 years, 5 months ago by
andrewk.
October 28, 2004 at 2:49 pm #6649
andrewk
ParticipantHi Guys,
Is it possible for a non-expert to replace the door seal of an Indesit WE 16 washer??The seal is starting to split across a crease which has formed towards the top of the seal. This crease seems to have been caused by the factory fitting the seal with a slight twist between the door rim and the drum bead. As usual the machine is just out of warranty!!!!
The seal is spring and wire retained to the lip on the case on the door side, but I don’t want to investigate further on the drum side if I’m on a hiding to nothing.
Any comments will be most gratefully received….
ThanksAndrew
October 28, 2004 at 3:09 pm #118866Martin
ParticipantRe: Indesit WE 16 UK Door Seal replacement
Andrew,
It’s not too difficult a job really and can be accessed from the top. (Pull the plug first though) There are a couple of different seals that fit that model so the serial number can decide which 😉
October 28, 2004 at 3:52 pm #118867andrewk
Martin,
Thanks for the instantaneous reply 😀 …The serial number is :- 211288234 * 80251620100
The seal is retained to the drum bead by what seems to be an oversized wire circlip. This looks to be “interesting” to replace after refitting the seal. Do I need special tools to pull the ends of the wire together before the hooks engage??
Thanks again…
Andrew
October 28, 2004 at 4:04 pm #118868Martin
Andrew,
I think it may be tricky for you but anyway, the part number you need for the new seal is : C00064545. It may well be available via out “shop@” site in the navigation bar?
Any problems I suggest getting a local independant engineer to do it for you 🙂
October 28, 2004 at 5:19 pm #118869Dave_Conway
Martin wrote:It may well be available via our “shop@” site in the navigation bar
It is now 😉
Here : http://shop.ukwhitegoods.co.uk/c0006454 … -door-seal
October 28, 2004 at 6:01 pm #118870andrewk
Dave and Martin,
Many thanks to you both for your help.I’ve ordered the seal from Shop@ and if I hit problems fitting it I’ll repost to try and get a recommendation for an independant engineer local to me….
ThanksAndrew
PS
Dave,
The listing of machines in Shop@ suitable for fitting with C00064545 does not yet include the “WE 16 UK” variant.A
October 29, 2004 at 7:40 am #118871Dave_Conway
andrewk wrote:The listing of machines in Shop@ suitable for fitting with C00064545 does not yet include the “WE 16 UK” variant.
Sorry, I hurriedly copied it over from a database I have, WE16 is now on the list, thanks for pointing it out.
