Re: Indesit WE12 screeching noise
pinktransit wrote:How difficult are the bearings to replace?
On a scale of 1 to 10 (10 being the hardest) I would say 11 🙁
Only because the effectiveness of bearing replacement on these machines is well below par. Poorly constructed machine where the drum shaft cannot be accessed or replaced often means a bearing replacement is little better than a bodge job!
If the screeching is the bearing that is…….? Have you checked the pump firstly???
