Indesit WE14 F-12 what does it mean?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WE14 F-12 what does it mean?
  • #8877
    #130884
    Re: Indesit WE14 F-12 what does it mean?
    It is a likely communication error between the 2 circuit boards behind the control panel. Best get an engineer in to check it for you 😉
    Try our own list to see if we have one in your area?
    Repairs@
    Is this likely to be expensive.
    It is older than 3 years 🙁
    #130886
    Worst case scenario???….up to £100 max 🙄
    had same error on a WE16.
    fixed it in 2 minutes flat.
    yes i did disconnect from wall prior to taking lid off.
    #130888
    g7pkf wrote:fixed it in 2 minutes flat.
    Radio Hams everywhere on this site it seems 😆
    #130889
    Jim_1
    hi…generally means loss of communication between the two control boards….ie the digital programe display and the main control module..however be wary here both boards contain EPROM chips and it is usually down to corrupted instructions on either one or both EPROMS..you will require model and serial number of appliance to obtain spares …quite frankly you need an Engineer to identify the fault/s and dependant on the age and condition of the appliance perhaps change it…These appliances were plagued with this type of fault….have a nice day
