indesit we14 fault code -H20
Home Forums Public Support Forums Help And Support Washing Machine Help Forum indesit we14 fault code -H20
  • #5232
    I have an indesit We14 its about 2 years old. Onthe number 4 wash towards the end of the cycle, I’m getting an error message -H20, if I switch the machine off and just do the spin cycle it clears the error message . It doesn’t seem to affect the quick wash cycle. Can any body help? Thanks
    #110031
    Re: indesit we14 fault code -H20
    Denise,
    I haven’t heard of error code H20 on one of these machines before, in fact the error messages are usually prefixed by the letter “F”. Having said that I feel it may well be a pumping out problem. A possible blockage to the pump, check behind the front ‘Kick Panel’ on the R/Hand side to access the pump.
    I suspect the machine goes into an error default mode due to timing out whilst draining. Resetting the machine onto spin clears the problem in these cases.
    Hope that helps?
    Thanks for that. It seems to have cleared the problem at the moment.
    Denise
