indesit we16
Viewing 15 posts - 1 through 15 (of 17 total)
  • #14164
    gaz1970
    Hi, I hope someone can help me with my we16 washing machine
    It has worked well for 4 years and now when you select a program it dose not fill or appear to start washing. It also said DOOR on the LCD a few times if that gives any clues, also it appears to go through the whole cycle but throws no error codes up
    any help would be appreciated before calling a technician
    #158402
    gegsy
    Re: indesit we16
    I would imagine door interlock a fault to be honest.
    gaz1970
    Re: indesit we16
    hI
    THANKS FOR QUICK REPLY
    I have just had door interlock switch off front door, I can see the plastic strip that is pushed to the left by the closed door to activate switch, but i can not see how it moves the small black lever on theend of the switch which activates it, could there be something broken off the housing
    is it a switch assembly that i order from indesit? or switch and housing seperate
    #158404
    gegsy
    Re: indesit we16
    After a period of time they get “lazy” best option would be to change the lock.
    Goto spares@ Im sure you will get sorted there.
    Re: indesit we16
    P/no C00011140 or C00085194 are suitable locks for this appliance. An email to spares@ukwhitegoods.co.uk for prices and ordering.
    gaz1970
    Re: indesit we16
    will send e-mail now
    Thanks for helping
    #158407
    gaz1970
    Re: indesit we16
    Update
    My mum has the same washing machine so I tried the door interlock on her washer, hers works OK with the switch fitted, Any other suggestions welcome
    #158408
    gegsy
    Re: indesit we16
    Could be a fault with the door catch, take your mums door off and try it on your machine 😆
    gaz1970
    Re: indesit we16
    Hi thanks for replying
    I tried the whole door interlock assembly
    #158410
    gegsy
    Re: indesit we16
    Ok did you try the door complete with latch and/or electronic door lock on frame of appliance??
    gaz1970
    Re: indesit we16
    the whole assembly from behind the the front panel switch and slider
    #158412
    gegsy
    Re: indesit we16
    and the door complete as the striker/latch could be faulty?? 😕
    gaz1970
    Re: indesit we16
    never tried the door itself as I thought that was ok because it locks and wont open but could be wrong I suppose
    #158414
    gegsy
    Re: indesit we16
    Try yours on yer mums or vice versa just to eliminate 😉
    gaz1970
    Re: indesit we16
    I changed the door over but same problem
    I decided to have a look at control PCB at back ond there is a big black burned out patch with a transistor blown and a track on PCB burnt through I know I will have to replace this but do you think for it to be blown like that it could be a motor etc aswell that has done it so scrap it?
