Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › indesit we16
- This topic has 16 replies, 3 voices, and was last updated 20 years, 3 months ago by
gaz1970.
December 19, 2005 at 6:11 pm #14164
gaz1970
ParticipantHi, I hope someone can help me with my we16 washing machine
It has worked well for 4 years and now when you select a program it dose not fill or appear to start washing. It also said DOOR on the LCD a few times if that gives any clues, also it appears to go through the whole cycle but throws no error codes up
any help would be appreciated before calling a technician
December 19, 2005 at 8:16 pm #158402gegsy
ParticipantRe: indesit we16
I would imagine door interlock a fault to be honest.Greg
December 19, 2005 at 8:27 pm #158403gaz1970
hI
THANKS FOR QUICK REPLY
I have just had door interlock switch off front door, I can see the plastic strip that is pushed to the left by the closed door to activate switch, but i can not see how it moves the small black lever on theend of the switch which activates it, could there be something broken off the housing
is it a switch assembly that i order from indesit? or switch and housing seperate
December 19, 2005 at 8:33 pm #158404gegsy
After a period of time they get “lazy” best option would be to change the lock.
Goto spares@ Im sure you will get sorted there.Greg
December 19, 2005 at 8:38 pm #158405Penguin45
P/no C00011140 or C00085194 are suitable locks for this appliance. An email to spares@ukwhitegoods.co.uk for prices and ordering.
Penguin45.December 19, 2005 at 8:54 pm #158406gaz1970
will send e-mail now
Thanks for helping
December 20, 2005 at 5:25 pm #158407gaz1970
Update
My mum has the same washing machine so I tried the door interlock on her washer, hers works OK with the switch fitted, Any other suggestions welcome
December 20, 2005 at 6:24 pm #158408gegsy
Could be a fault with the door catch, take your mums door off and try it on your machine 😆
December 20, 2005 at 6:30 pm #158409gaz1970
Hi thanks for replying
I tried the whole door interlock assembly
December 20, 2005 at 6:44 pm #158410gegsy
Ok did you try the door complete with latch and/or electronic door lock on frame of appliance??Greg
December 20, 2005 at 6:47 pm #158411gaz1970
the whole assembly from behind the the front panel switch and slider
December 20, 2005 at 6:49 pm #158412gegsy
and the door complete as the striker/latch could be faulty?? 😕
December 20, 2005 at 6:50 pm #158413gaz1970
never tried the door itself as I thought that was ok because it locks and wont open but could be wrong I suppose
December 20, 2005 at 6:51 pm #158414gegsy
Try yours on yer mums or vice versa just to eliminate 😉
December 20, 2005 at 9:50 pm #158415gaz1970
I changed the door over but same problem
I decided to have a look at control PCB at back ond there is a big black burned out patch with a transistor blown and a track on PCB burnt through I know I will have to replace this but do you think for it to be blown like that it could be a motor etc aswell that has done it so scrap it?
