indesit we16 uk
Home Forums Public Support Forums Spare Parts Help indesit we16 uk
  • #9523
    hi all,
    lookin for a pcb/module for the above washing machine.
    just before it started to smoke we got an error code f 12…. any ideas please.
    the blue label on the module says CCD or COD.215005377.30
    there is Ariston FE to the left side and 39-01 top left.
    i have found simular looking boards for all others exept this machine 🙁 🙁 🙁
    cheers
    kerplunk.
    #134466
    Re: indesit we16 uk
    Pcb is p/no C00084331, and is supplied without the eeprom fitted. Contact spares@ukwhitegoods.com for price and availibility etc.
    Regret fault 12 does not seem to be a valid fault code – however it is always worth checking the heater circuits on these.
    Re: indesit we16 uk
    thanks for that,
    just to be sure this is the right pcb, it is the one near the floor to the left when facing the back 100mm x 250mm approx.
    eprom?? scuse my ignorence.. 😳
    cheers
    kerplunk
    #134468
    clyde
    Re: indesit we16 uk
    kerplunk wrote:thanks for that,
    The eprom is a little microchip that plugs into the module giving the applaince it’s correct features/identity
    The WE16 is part of the evolution range which carries a 5 year parts guarantee with indesit so for around £90 they will fix it for you,
    Regards
    Clyde 8)
    #134469
    Re: indesit we16 uk
    F12 is no comunication between theconsole and main power board, may need both boards aslo the connections between the may just need a fiddle with as this can cause same fault.
    #134470
    Re: indesit we16 uk
    thanks clyde 😉
    i checked with the uk hq and yoom correct 😀 😀 problem solved you may think!!
    not quite….. we live in brittany…. but it’s ok… they have european cover on this machine also 😀 😀
    thanks for your valauble help guys, i will let you know if i am successful with my warranty.
    salut :wave:
    #134471
    Re: indesit we16 uk
    Fixed mine in 2 minutes.
    unplugged power!!!!
    removed lid 2 screws at rear slid back
    found circuit boards on front dissconnected/reconnected one at a time using an eraser to clean board contacts.
    put lid on
    fault gone.
    DON’T DO THIS YOURSELF GET A QUALIFIED PERSON TO HAVE A LOOK.
    unless you are like me and like taking things apart! BUT DISSCONNECT MAINS FIRST
    #134472
    Jim_1
    Hi there…the F 12 fault is none communication between the control console and the main board in the base of the appliance…however both of these board contain eeproms…the fault could be as simple as a faulty connection at the control console and or the main board..if the appliance is under 5yrs old then all parts are free you just pay the service callout (£89.00) if the appliance is over 5yrs old id seriously consider scrapping the same..you must have the model and serial numbers of your appliance to obtain correct eeproms..and you may need a motor…merloni advise changing boards eeproms and motor …costly if your paying..good luck ..ex merloni engineer
