Indesit WG1034T Wont Drain
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WG1034T Wont Drain
  • #21789
    chojin
    Hi guys
    I own the above washing machine and it will not drain. I have set it to drain cycle 5-6 time and the water just goes around and around making more bubbles 😕
    My guess would be the Drainage Pump is knackerd. If so is it easy to change and cheap to buy?
    I have had the machine for approx 10 years so yes it owes me nothing but I am not realy in a position at the mo to shell out £250+ on a new one.
    Mark
    #192510
    Re: Indesit WG1034T Wont Drain
    The pump or sump hose are probably just blocked with a coin or something!
    POWER OFF BEFORE TAKING A LOOK!!! :zap:
    #192511
    chojin
    OK cheers for that. I will have a ganders tonight. I need to get it outside as its full of water :rolls:
    #192512
    chojin
    Well Martin. Took Half a day today from work to have a look after your advice. Was a bit of a monster to get down my kitchen step, but it came down with a MONSTER bang 😈
    Turned it on its side and disconected the hoses and use my garden hose to jet up the pipes. Nothing major came out, but it may have been just soap scum. Reconected everything destroyed my kitchen step getting back in 😕 ( i was using a sack truck)
    Well its in and draining 😆 and spinning so all is looking good 😀 . Not sure if it was the cleaning or the MONSTER bang that did it 😆 . So fingers crossed the cycle finishes.
    #192513
    I know it’s after the event, but why didn’t you just drop the drain hose into the washing up bowl and let gravity do the work?
