Do you mean it’s filling on it’s own? If so, check for backfilling from the sink if that is where the drain pipe is connected and for leaky water inlet valves.
Pull the plug first if you’re going to look at the valves. :plug:
doctorp wrote:hi, any1 have any ideas or come across this problem with the indest machine, water collects and th dainage system appears to be ok
thnx P
If its filling up all the time refer to penguins post:
or do you mean its full of water after its been on a wash? this would indicate
a pump or filter problem, if you put it on prog 7 you should hear the pump running.
