My WG1130T has a drum problem. This has happened before but I managed to fix it.
The drum came loose and started banging a lot when rotating. I managed to fix it as I found it was being held in place by two lots of plastic stabiliser thingys either side and one of them had come out. It seems to have come loose again. Can anyone help as to what can be causing this? Don’t particulary want to pay anyone to come out and look at it.
Many thanks.
AK
Overloading for the most part will cause suspension problems 🙁
Make sure the ‘friction pads’ are fully located in their sockets and that the drain pump is clear and able to discharge the water without any restrictions (waste hose couplings blocked etc).
