Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit WG1130T
- This topic has 19 replies, 6 voices, and was last updated 22 years, 2 months ago by
admin.
February 9, 2004 at 7:16 pm #5140
KeymasterI had to turn off the power to my machine in the middle of a cycle and since then it fails to complete.
It gets to the point where it should ‘spin’ and empty but then just stops??
I have tried turning off at the mains and reseeting etc…any ideas please
February 9, 2004 at 8:34 pm #109171Martin
ParticipantRe: Indesit WG1130T
Almost certainly the pump is blocked and not draining off the water.( It needs to drain off 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the water before it will spin) However if it is draining off the water but still won’t spin, then it more likely the Motor is the problem and more specifically, the Motor Carbon Brushes are worn out and need replacing.
Any local repair company could advise beyond that. DO NOT ATTEMPT REPAIRS YOURSELF!
February 9, 2004 at 9:17 pm #109172admin
KeymasterRe: Indesit WG1130T
Thanks, but how do I check for a block?, because it is not draining off
February 10, 2004 at 7:57 am #109173Martin
jimbo1 wrote:Thanks, but how do I check for a block?, because it is not draining off
The pump is accessible on the front right hand side. To drain the water off, lower the drain hose into a bowl or bucket until empty. Remove the tub to pump hose clip and check for blockage within the pump chamber and the sump hose.
PLEASE DISCONNECT FROM THE MAINS BEFORE ATTEMPTING REPAIRS!
February 10, 2004 at 1:29 pm #109174admin
Martin,
Fantastic!!!..I have cleaned everything out (what a mess) and it now works fine.
You have saved me a fortune on call out charges.
THANK YOU 😀 😀
February 19, 2004 at 5:00 pm #109175admin
jimbo1 wrote:Martin,
THANK YOU 😀 😀
Martin, I have a similar problem with the same type of machine. The pump is clear and all the water drained. The drum motor continues to run at the ‘wash’ speed and will not spin. The programme knob contiues round Ok. Just before the spin is supposed to start the motor does pick up speed a little then goeas back to the ‘Wash’ speed. Does the machine think the load is not balanced? I can’t get it to work even with no load. Any ideas?
Pablo.
February 19, 2004 at 7:47 pm #109176bonzaco
When I used to work for Merloni this was a classic module problem. Machine would progress through the program but would refuse to do final spin. I suggest you put your postcode on the forum and Im sure someone will supply either a module or labour and module for reasonable price. Good luck – Bonz
February 20, 2004 at 8:44 am #109177Martin
Pablo
I also think I would suspect the Module or at least the connector block to the Module (some contact may have burnt?)
Good luck !
February 20, 2004 at 9:01 am #109178Pablo
Thanks Bonz, strangely enough in desperattion, I was a little more rough in the operation of the programmer knob than I should have been and it’s fixed!! This will be tempory though as this is the third time that the fault has occured (this though, was the longest outage). Next time it does it I will get a price on replacing the module.
Thanks again
Pablo
February 20, 2004 at 9:07 am #109179Pablo
Martin / Bonz, thanks again for your help. Silly question time? Is the programmer knob that I turn the ‘module’ or is the module something else?
Regards
Pablo
February 20, 2004 at 9:53 am #109180Dave_Conway
Pablo wrote:Martin / Bonz, thanks again for your help. Silly question time? Is the programmer knob that I turn the ‘module’ or is the module something else?
It’s something else.
Pablo, as Bonz suggested, it may be worth you putting you’re postcode up here and ask for an engeineer to call out. Please don’t take this the wrong way but it is evident that you do not have much of a clue what you are looking for, and in that respect it is best left to those that do as you could well do more harm than good and cause yourself unnecessary expense.
Regards.
March 24, 2004 at 6:19 pm #109181admin
I know it seems simple, but is it possible that the connection to the Spin-speed button has become disconnected and hence it is now only spinning at the lower speed?
May 16, 2004 at 9:36 am #109182admin
I too have had a problem with the power and then the machine not working! You can set the machine to the programme(1-4) and it fills with water and then just stops, doesn’t do anything. I can then turn it to programme 5 and the machine works fine. Any ideas to the problem, or anywhere that I might be able to get a hold of the manual???
Thanks,
Shaun.May 16, 2004 at 2:22 pm #109183admin
this may be caused by the appliance not being able to heat the water during wash,try it on a cold wash and see if it goes through ok,if it does then i suspect a fault on the thermostat or heater assembly,you will need to arrange for a engineer to carry out these repairs.
bryan
September 27, 2004 at 6:18 pm #109184admin
KeymasterHey – I found this topic really helpful. Went straight to the pump & found a 5p coin in it.
Works a charm now – thanks guys.
Alasdair.
