Indesit WG1185 – why is drum not running concentric?
Home Forums Public Support Forums Help And Support Indesit WG1185 – why is drum not running concentric?
  • #101074
    birdonthewire
    Are there any washing machine experts who could suggest why the drum on my Indesit WG1185 washing machine is not running concentric?
    I’ve just replaced the door seal after the last one got shredded but have now noticed that the drum is not running true, and is abrading the new door seal during the spin cycle, accompanied by a loud rumbling noise.
    I turned the drum while fitting the new door seal and couldn’t find any play in the bearings or loose counterweights, etc, and the machine runs fine throughout the rest of the programme).
    Any guidance would be much appreciated!
    Thanks all
    #483246
    drum spider corrosion
    bad news is you need a new one
    birdonthewire
    Thanks Electrofix.
    However, I checked the spider, which seems fine; it’s firmly secured to the drum and there’s no play in the bearings.
    Where and how might rust be an issue?
    #483248
    you cannot check the drum spider without taking the inner drum out
    you machine has 2 spiders. one holing the bearings the other bolted to the back of the revolving drum
    birdonthewire
    Ah, I see – thanks Dave.
    Sounds like a difficult repair so I’m guessing it would be better to buy a new one. Could you recommend an affordable make/model that is reliable – and cheap to fix?
    Paul
    #483250
    look at the Bosch WAN series
    cant promise its cheap to fix but you do get 2 years warranty and we can get all the spares
    if you want Quality you want Miele but
    Ebac have started making machines and they claim its repairable and seems to have good feedback so far
    birdonthewire
    OK, will check it out.
    Thanks for your expert help and advice, Dave – it’s much appreciated!
    Paul
