Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › INDESIT WG1230G
- This topic has 10 replies, 3 voices, and was last updated 16 years, 3 months ago by
revit.
January 7, 2010 at 10:21 am #51450
revit
ParticipantHi There, I am looking for a wiring diagram or fault diagnostic info for the above washing machine. The machine had trouble spinning fast and would work intermittently however today the drum stop spinning at all evening i wash mode! I believe the fault is the control switch which if is correct will render the machine to the scrap yard given the cost of the switches. I am planning to take a second look at the weekend, i have so far checked all of the obvious stuff but will be looking at the switch in more detail with the meter. Any available info would be appreiciated. cheers revit
January 7, 2010 at 10:57 am #308082iadom
ModeratorRe: INDESIT WG1230G
Rule #8 applies.
The first thing to check is the motor brushes. 😉
January 7, 2010 at 12:09 pm #308083Phidom
ParticipantRe: INDESIT WG1230G
If the timer has failed you may be able to get it repaired by these people:
January 8, 2010 at 12:18 pm #308084revit
Thanks guys, will take a look at the motor tonight to see if the brushes are the cause. Thanks for the link for the Switch repair it could mean there is life in the old dog yet! Can’t complain too much machine is 13yrs old now!
Cheers guys will post an update after the weekend.
January 8, 2010 at 2:51 pm #308085iadom
revit wrote: Can’t complain too much machine is 13yrs old now!
Don’t be tempted to buy another, think months rather than years. :rolls:
January 10, 2010 at 9:07 pm #308086revit
OK guys had a look at the brushes took em out and cleaned them up! the motor is now working again although the high speed spin seems to work some times and not others. I have order new brushes anyway for a tenner from ebay as they looked very low. Will change em and see what happens!
Cheers for your help! Will post an update as and when brushes installed.
January 10, 2010 at 9:27 pm #308087iadom
I would strongly advise that you do not run the machine with worn brushes, if it arcs across the comm it could take out the PCB.
January 13, 2010 at 5:45 pm #308088revit
Got new brushes from ebay, got them today wrong ones sent them back waiting for replacements the olds look really worn down!
January 13, 2010 at 8:28 pm #308089iadom
Why bother with fleabay, the Shop@ on this very site would almost certainly have the correct brushes, a good chance they would be cheaper too. 😉
January 14, 2010 at 3:03 pm #308090revit
Fair comment if I am honest I forgot this site sold spares as would have purchased from here just because of the advice received, will buy from here in future. Rgds
:rolls:January 18, 2010 at 4:37 pm #308091revit
All sorted so far so good, although the machine now sounds a bit thrashy at certain rpm’s but apart from that seems to be flying ok with the new brushes.
I assume the bearings are worn as well hence why it is a little nosiy.
Thanks for your help
