indesit wg1432 bearing noise
Home Forums Public Support Forums Help And Support Washing Machine Help Forum indesit wg1432 bearing noise
  • #19839
    sootyfishing
    Hi, I have an indesit wg1432 washing machine that makes a terrible noise whilst spinning. I think this is a bearing problem and I would like to fix it. How could I take the bearings out, and what would be the cost of the bearings ? Thankyou any help you could give would be appreciated..
    #184743
    Re: indesit wg1432 bearing noise
    sootyfishing wrote: How could I take the bearings out, and what would be the cost of the bearings ? .
    The bearing spider has to be removed, the old bearings removed and then reassembled. 2 bearings and water seal (Part No’s C0082696, C0044765 and C0013563) will set you back around £25 – £30. (Available via spares@ukwhitegoods.co.uk )
    Expert help from a local engineer can be sort by clicking the link below. 🙂
    #184744
    sootyfishing
    sorry about the delay, thankyou for your advice. parts are on order so i hope to fix it soon. is it easy enough to take the bearing spider out??
    #184745
    You can remove the drum support easily enough – 8 Torx bolts. The real problem is getting the pulley off – the bolt can be a real swine to get off.
    sootyfishing
    success!!!
    I now have a washing machine that works. The bearings are good and the advice I have got from this forum has saved me a lot of time and money. Thankyou to all of you..
