Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit WG9 not Spinning
- This topic has 12 replies, 4 voices, and was last updated 20 years, 3 months ago by
hmmm.
December 30, 2005 at 6:28 pm #14403
hmmm
ParticipantFirst off, let me just say hello as this is my first post here :wink:.
Secondly I have a Indesit WG9 Washing Machine :oops:. Not a good start, I know.
The machine was washing when I turned the Switch to stop it from rinsing, and heard a little bang.
Now the drum doesn’t spin at all 😡 and my mum’s blaming me
:cry:.I checked the pipes where clean and some sludge did come out. I blew in to the pipe which is connected to the Pressure Switch and I heard some clicking so I assume that’s fine.
Any ideas? Need to get this sorted or i’ll never hear the end of it :wink:.
Thanks.
December 30, 2005 at 6:30 pm #159300Simon46
ParticipantRe: Indesit WG9 not Spinning
Can you check the model number again?
Regards
SimonDecember 30, 2005 at 6:33 pm #159301hmmm
ParticipantIndesit WG 9. Around 5 years old. It’s a very basic machine and cost around £140 when I bought it.
December 30, 2005 at 6:57 pm #159302Penguin45
There was a WG924……. Check labels for info, not control panel. There should be one in the door porthole and one on the rear of the machine. If it is a WG924, you have almost certainly blown the electronic board.
Power off if you are investigating further.
Penguin45.December 30, 2005 at 7:00 pm #159303Simon46
Yes found WG9. Sounds like electronic module may have popped. Unplug power if you are going to have a look yourself :zap: .
Regards
SimonDecember 30, 2005 at 7:08 pm #159304hmmm
Just checked the back. This is what it says:
Indesit WG 9 G
S/N 811230244
461777600005KG 900 RPM :oops:.
Type Number LB 4684 C.
Thanks.December 30, 2005 at 7:10 pm #159305hmmm
ParticipantHow much does it cost for a new Electronic Module?
Is there anyway to test this before purchasing / replacing?
Or am I better off buying a new machine?
Many thanks. I appreciate your help :D.p.s The water fills and drains etc but drum does not spin :wink:.
December 30, 2005 at 7:17 pm #159306Penguin45
It will almost certainly be visibly blown if you had a pop noise…..
December 30, 2005 at 7:19 pm #159307hmmm
ParticipantIS the electronic module the one behind the dial knob?
Any idea on the rough price of one please?
Thanks.
December 30, 2005 at 7:44 pm #159308Penguin45
That’s the timer unit – look for a printed circuit board. They range from £45 – £85 depending on which one’s fitted – post up the numbers on the heatsink for an exact price.
December 30, 2005 at 8:30 pm #159309hmmm
ParticipantI think even £45 is too much to spend on it.
Probably buy a new one.
After doing a search, it seems that it’s best to go with a Bosch Washing Machine. My Budget is £400.
I was thinking of the Bosch WFX2868GB 1400 Spin Washing Machine.
Is this a good choice?
Thanks again.
December 30, 2005 at 9:35 pm #159310Dave_Conway
Yep, that’s a good choice 🙂
Just for your benefit, the WG9G module is part number C00066454 at £48.68 ex VAT and carriage 😉
December 30, 2005 at 11:08 pm #159311hmmm
