Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › indesit Wi 335uk
- This topic has 7 replies, 4 voices, and was last updated 20 years, 1 month ago by
Johnnyboy.
February 16, 2006 at 3:17 pm #15689
Johnnyboy
ParticipantBeen to a call yesterday pulled a coin out from the pump, yipee. 🙁 recall to the same machine today , no action when a programme is selected, inc spin & drain. Door lock light is on and door wont open, heater is ok NTC is within range and motor buzzes out ok. I am left thinking it is the PCB and EPROM but at lots of quids to try its a bit of an expence, not to mention looking a charlie if it don’t work. Anything else I should be looking ot for. There are no flashing error codes.
February 16, 2006 at 4:15 pm #166020Martin
ParticipantRe: indesit Wi 335uk
Would the machine you’re talking about be an W133SUK I wonder as I cannot see a WI335UK listed????
If the former applies, have you set the dial on one of the BLACK DOTS and ‘reset’ the programmer first of all, to see if that clears it?
Are you listed as a Trade Member?
February 16, 2006 at 4:26 pm #166021Johnnyboy
Sorry it is that model, yup I am tradel isted and I have reset the dial each time I tried a new prog. nothing more annoying than a machine just looking at you.
February 16, 2006 at 4:44 pm #166022Martin
Johnnyboy wrote:yup I am trade listed
Welcome to the site Johnnyboy 😀
I have moved your post into ‘Trade technical’ please do not post trade stuff within the public forums 😉
If your machine will not reset then I can only assume a module/eeprom problem. You can of course sent them to EMW for them to test it for you. (I’m not sure if you knew that?)
February 16, 2006 at 4:53 pm #166023Johnnyboy
Oops this is my first try at posting anything. I understand that you have to order a pre programmed eeprom and board, as we do not have the facillities to test/programme that model. Cheers
February 16, 2006 at 4:55 pm #166024Martin
Johnnyboy wrote:as we do not have the facillities to test/programme that model. Cheers
That’s why I gave you the link to EMW who can do that for you 😉
February 16, 2006 at 6:01 pm #166025gazza57
normally these boards show blown tracks when faulty, did you disconnect motor plug to check across terminals, if top 2 pins on motor are open circuit it can cause your problem.hope this helps rgds gazza.
February 16, 2006 at 9:03 pm #166026bubs
It’s a bit unlucky for the pcb to go the next day, maybe the pump connection has come loose as you had it apart; Not too sure if it stops fill on the indes*** but I have been caught out by this before.Graeme
