I need to change the heating element on my Indesit WI101 as seems to be a direct connection between the red suplly connector and earth. Does anyone know how i get it out?
Can’t be certain about the particular model you’re talking about, but usually the element is held in place by a nut tightened on to a metal plate. If you remove the nut the element should just pull out. It might take a bit of a tug to free off the rubber seal behind the plate. Isolate the machine from the mains before attempting this! (that means take the plug out of the socket)
