indesit wi101
  • #44833
    simonb
    Hello all,
    had same thing on 2 machines now so i thought id post,
    fault is only thing happens is fill only, wont reset and wont drain spin etc, the actual fault with machine is weight has sheered off drum, so id expect timer would be ok? last machine was a blockage in pump? any reset procedure? iv tryed usual onto off and hold down cancel etc,noticed it has removable EPROM?
    thanks
    simonb
    #282511
    helo_75
    100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} board failure
    need smart card,reader and low end adapter… or give emw a call
    #282512
    helo_75
    although saying that, they do work slightly diff to the usual boards, you need to turn the knob to the 12 o’clock position (off) if it doesnt reset.. like i say, pcb failure
    #282513
    Tony_EMW
    Re: indesit wi101
    In stock, ready programmed – £39.90+vat inc post http://www.emwelec.co.uk
