Indesit wi101 problem
  • #62926
    delibeli
    I have an indesit wi101, how is the internal spinning drum attached? mine has either come loose or broke off. Thanks in advance.
    #351945
    Re: Indesit wi101 problem
    The best advice is to scrap it, it has a totally sealed drum and a very thin. flimsy drum support that will have rotted through.
    This is caused by using liquid detergents and only doing low temperature washes.
    A new drum assembly is around £100, the machine is just not worth it. :rolls:
    #351946
    washtronics
    i agree, these machines are not designed to be repaired by anyone other than inde****! sealed tanks & modules that need to be reprogrammed. if its not a heater/pump/belt/loose weight or door-forget it
    #351947
    nzjedi007
    Indesit wi121 problem
    Wash begins then drains switch continuosly turns while fault light flashes twice in sequence… Any Idea?
    #351948
    helo_75
    f2 – faulty motor
    if ur lucky, could just be brushes
