Indesit WI121 – Cycle is not starting – HELP!!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WI121 – Cycle is not starting – HELP!!
  • #31074
    danny_see
    Hi Guys,
    Im having a nightmare with my Indesit WI121 once the washer is loaded and set to program – I shut the door and nothing happens, the light comes on but stays on (it should flash and hear the water loading!).
    It stays like that and nothing happens, door does not seem to lock and you can open the door with the washer on.
    If you have any ideas to help me I would really appreciate it.
    Many Thanks
    Danny
    #229566
    Re: Indesit WI121 – Cycle is not starting – HELP!!
    Door lock not working? Won’t start until the door locks………
    danny_see
    Yeah the door shuts, but doesnt lock. Is there anyway I can fix this?
    Thanks for your help.
    Danny
    #229568
    Door lock is p/no 1603292. An email to spares@ukwhitegoods.co.uk will get things moving for you.
    Power off if you are going to do this yourself.
    rokinbenji
    Hi there I contacted spares@ukwhitegoods.co.uk stating part number which you gave and they told me that the part number was different i.e 1604781.When I recieved it it was smaller than the original part and the electrical connection doesnt fit.
    #229570
    As shown on the page for that lock here, there’s been several changes to it and several part numbers. Every time a supplier changes, a change to the part is made or someone sneezes, the part number changes.
    It’s just the way things work with part numbers but it does become rather confusing when you follow ten plus changes through trying to track stuff down. And, you often end up with parts that look to have little more than a passing resemblance to the original one. :rolls:
