Re: Indesit wi141 bearing replacement
The bearings are in a support spider on the back of the drum, not an easy repair. There are a couple of different types of drum bearing spider, also different drum shaft sizes meaning different bearings.
If you really feel up to it, the best thing to do would be to try and remove the spider and get the bearings out before you order any parts, also carefully examine the drum shaft. If the drum shaft is badly damaged, bin the machine and buy something better. 😉
Plug out and keep the elastoplast handy. :rolls:
