Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit WI141 Its got me beat!
- This topic has 13 replies, 7 voices, and was last updated 17 years, 9 months ago by
nelson.
July 10, 2008 at 8:34 pm #38023
nelson
ParticipantI have the above machine in the workshop, It came in with drum bearings needing replacing, it had also cut through the outer drum just above the heater.
I replaced the bearings and sealed the hole in the drum. Then when I tested the machine it started to fill then aborted the wash.
I had a look at the motor which showed signs that water had been around so tried an other motor on and again aborted the wash. Tried an other prussure switch, same thing, plugged in an other heater, thermistor and water pump same thing, tried an other program selector same thing. So I ordered a module from EMW plugged it in and yes once again aborted the wash cycle. I have replaced the motor plug as that was looking a little iffy but still no go.
The customer was not prepared to pay for more than the original work so I sold him a new machine. But I would like to get to the bottom of this as it has had a good bit of time from me.
I am pretty sure that I have covered all bases 😕 but if you can think of anything else……Cheers
July 10, 2008 at 8:38 pm #257429helo_75
Participantwhich lights flash when it aborts?
July 10, 2008 at 9:42 pm #257430Tony_EMW
ParticipantRe: Indesit WI141 Its got me beat!
Don’t forget to remove small plugs (blue wires) on board, nip with fingers (not pliers) and push back on. This can sometimes sort this problem
July 10, 2008 at 10:50 pm #257431nelson
Thanks Helo_75 and Tony
It doesn’t have any leds except for the door locked led which flashes when it aborts. Also I nipped up the small plugs before I fitted the replacement board.Cheers
July 11, 2008 at 3:49 pm #257432hotpnt
count the number of flashes between pauses, how many are you getting? (my bets on 8)
July 11, 2008 at 6:38 pm #257433Penguin45
Or even ( 8 ) ……
July 12, 2008 at 7:51 pm #257434nelson
Hello hotpnt and chris, I’ve just checked today and I am getting 8 flashes between pauses. ???? 😕 ????
Cheers
July 12, 2008 at 8:22 pm #257435helo_75
Participantheater relay sticking on pcb
known error codes
July 12, 2008 at 8:26 pm #257436Penguin45
Participanthelo_75 wrote:known error codes
Page THREE.
It almost invariably means that the pcb has gone faulty – you’ll need a new board and eeprom if the customers budget will stand it, or one of Tony_EMW’s finest re-conditioned ones – a good value for money solution on a budget appliance.
July 12, 2008 at 8:34 pm #257437helo_75
Participantalthough you did say you tried a pcb…
July 12, 2008 at 9:05 pm #257438iadom
ModeratorPenguin45 wrote:– a good value for money solution on a budget appliance.
Naw, still think Paul (goatboy) has the best solution. 😆
July 12, 2008 at 9:12 pm #257439Penguin45
Go on…….. remind me……
July 12, 2008 at 9:27 pm #257440iadom
ModeratorRe: Indesit WI141 Its got me beat!
Penguin45 wrote:Go on…….. remind me……
Trebuchet.
July 12, 2008 at 10:51 pm #257441gegsy
iadom wrote:
Penguin45 wrote:
Go on…….. remind me……Chris.
Trebuchet.
and there was me thinking he was part of the French international footy team 😆
