Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit WI141 washing machine fault
- This topic has 6 replies, 3 voices, and was last updated 20 years, 3 months ago by
PaulieMcc.
January 4, 2006 at 6:49 pm #14525
PaulieMcc
ParticipantTrying to find some info on Indesit error codes – the in-laws machine has the constantly rotating selector knob problem. I have read as much as I can on here and have asked them to count how many times the indicator light flashes – the answer came back it flashes twice, then three times quickly, then once, then goes off after that it appears to flash 8 or 9 times! Not sure if this is just random flashing or if it is the 8 or 9 times that I should concentrate on? Any ideas – we just want to know which part may be at fault so we can decide if repair is economic – the machine is only 18 months old.
Thanks in anticipation guys (and gals).
January 10, 2006 at 10:02 pm #159771PaulieMcc
ParticipantRe: Indesit WI141 washing machine fault
No clues then guys, the mother in law is pestering me!!!
January 10, 2006 at 10:05 pm #159772Penguin45
We’ll need the actual count Paul – ie 1-2-3-4-pause-repeat. This should be occuring once the dial is clunking round.
Penguin45.January 10, 2006 at 10:07 pm #159773Dave_Conway
If it is 8 and 9 which is possible but unlikely then it’s a heating control problem or the software on the main PCB is corrupt.
Power off if checking please :zap:
But I’d get an engineer out to be honest, check the repairs@ link below 🙂
January 12, 2006 at 5:00 pm #159774PaulieMcc
Thanks for the info to date guys. I have been round to double check and the machine is definately only flashing eight times (repeatedly). So wheres the problem and a rough estimate of repair costs would be much appreciated. Then I can advise whether to go ahead and arrange repairs or buy a new machine.
Thanks again
Paul
January 12, 2006 at 5:25 pm #159775Dave_Conway
8 flashes is a heat control problem relating to the PCB or a component failure on it.
Knowing Indesit fault codes, one of half a dozen problems could be the cause though 🙁
January 12, 2006 at 10:44 pm #159776PaulieMcc
Many thanks Dave, I’ll get it looked at!
Paul
