I have a Indesit WIA101 that wont programme. All the machine will do is overfill, it is working on the pressure switch, but wont stop till it is above the door glass, the led prewash/wash light is on along with the door lock light. I also can’t cancel the programme as stated in the instruction book. The also machine fills in the off position and tumbles when trying to cancel the programme.
the machine is approximately 3 years old and had light use. 😡
Any ideas as to whats wrong
Thats ones easy to answer, just type Indesit into the ‘search’ facility and you will soon see what I mean. :rolls:
If the pressure hose that leads to the pressure switch is clear and does not have any small holes in it where it may have rubbed against the inside of the machine then there is a very strong possibility that the main PCB has failed.
Many thanks, I Think its the control board. Pressure system working OK.
Yet another “Quality” machine bites the dust.
My advice
👿 DO NOT BUY INDESHIT oops INDESIT!!!!! 👿
