indesit WIA 101 uk
  • #61459
    slyp98
    prob with this washer guys , starts and runs ok for about 15-20 mins , when it empties water the door lock led starts flashing rapidly and the anti- crease led and the the 2nd led from the top, rinse i think starts flashing also anyone have tech info on these models cheers k
    #346255
    whiskey_six
    Re: indesit WIA 101 uk
    anti crease is number 1 and then the 3 below are classed as 2.3 & 4. Looks like f10 error
    LCD
    Display
    Code*
    Console LEDs Possible Causes & Actions
    Refer also to Additional Fault Code Details
    for more information
    Key 1 Key 2 Key 3 Key 4
    F01 OFF OFF OFF Flash Motor triac short circuit: check motor & module connections
    F02 OFF OFF Flash OFF Motor jammed / tacho detached: check motor
    F03 OFF OFF Flash Flash NTC short/open circuit: check thermistor & module
    connections
    F04 OFF Flash OFF OFF Pressure switch jammed on empty: check switch & module
    F05 OFF Flash OFF Flash Pressure switch jammed on full or pump blocked: check
    pump & switch
    F06 OFF Flash Flash OFF N/A
    F07 OFF Flash Flash Flash Heater relay stuck: check heater and module connections
    F08 Flash OFF OFF OFF Heater relay stuck: check pressure switch, heater & module
    connections
    F09 Flash OFF OFF Flash Setup error: check eeprom
    F10 Flash OFF Flash OFF Pressure switch not sensing: check switch & module
    connections
    F11 Flash OFF Flash Flash Pump cannot be activated: check pump, connections &
    wiring
    F13 Flash Flash OFF Flash N/A
    F14 Flash Flash Flash OFF N/A
    F15 Flash Flash Flash Flash N/A
    F16 OFF OFF OFF OFF N/A
    F17 OFF OFF OFF Flash Door lock error: check door, door lock & module connections
    F18 OFF OFF Flash OFF Communication error (3 phase motor): replace power
    board
    #346256
    slyp98
    cheers whiskey 6, will check it out ,
    #346257
    slyp98
    worked fine until last week , goes through any cycles in about 20 mins takes in water , does a quick drum agitation 7 mins , takes in about 8 litres of water slow drum agitation then drains, a quick spin takes in 8 more litres slow rotation again and drains finished also only heats water to around 15 or 20 degrees and 156 volts going to element ,, main module problem?
    #346258
    allan73
    My guess would be main module 🙁
    Allan
