Indesit WIA 121UK module
  • #70025
    allan73
    I’ve just ordered a module for the above and have been told by Qualtex that an eeprom will also be required. This module is located behind the facia not at the bottom of the m/c where they usually reside and I cannot see a plug in point for a smart card reader etc.Can some kind soul advise if a eeprom is required, or if it’s a plug in and play type ?
    Allan.
    #376802
    allan73
    Re: Indesit WIA 121UK module
    Sorry should have said, the pt no for the module I’ve ordered is : C00143067.
    Allan.
    #376803
    allan73
    Sorry, should have searched :rolls: apparently it does require a plug in eeprom.
    Allan.
    #376804
    allan73 wrote:Sorry, should have searched :rolls: apparently it does require a plug in eeprom.
    Allan.
    EMW be the way for all issues Indesit modules and eeproms. 😉
    #376805
    allan73
    Might just do that Martin 😉 but out of interest, I’m assuming that a smart card is not required to programme these should I get an eeprom from Qualtex ?
    #376806
    BobHope
    you may be lucky and the eeprom might be available, if not you use a blank one and programme it with the smartcard reader/writer with the low end adaptor attached.
    Bob.
    #376807
    allan73
    Thanks Bob.
    Allan.
    #376808
    Allsorts
    If the eeprom is a plugin one then see if the one on the old board is good, as that will already be programmed.
    George
    #376809
    allan73
    I will need to check if the old eeprom is surface mounted or a plug in type Allsorts. It’s in a holiday cottage and I’m having difficulty getting access at the moment. The m/c’s hardly been used, most people staying there take the washing home with them.
    Thanks for the input.
    Allan.
