indesit wia101
  • #29445
    Galway
    hi all,this m/c stopped in mid cycle customer said as her nephew was playing with buttons!she said.i called and there was still water in it and could not get it to do anything after you select the program.it just sits there and door does not lock.is there anyway to bypass this door lock as a test.?the terminal to it seems to be getting a live and 2 neutrals.
    any help appreciated!
    thanks
    #223110
    Re: indesit wia101
    Galway wrote:the terminal to it seems to be getting a live and 2 neutrals.
    thanks
    If you twist plug you will get 2 lives & 1 neutral…. 😉
    After select program push “start” button…
    Kid’s cannot do anything from buttons which cannot be repaired… only if you have there time delay which is activated…
