Indesit WIA101 – aborting wash
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIA101 – aborting wash
  • #36703
    nelson
    I am going to see this one tomorrow, customer reports that when the machine is set on a wash cycle it fills, stops fills a bit more then has about half a turn then drains off and the following lights flash door lock, washing and anti crease. machine has to be switched off at the mains.
    She said that she tried the machine on a spin only and that worked ok.
    I presume that the flashing lights are giving a fault code but I can’t seem to find anything to tally up in the “Known Fault Codes” Any help most welcome.
    #251999
    helo_75
    need to know the order of lights
    i.e 1&4 or 2&3
    then itll be in the fault code list
    #252000
    nelson
    Re: Indesit WIA101 – aborting wash
    The anti crease is one of two options, from left to right it would be no.2, then the wash light is one of three lights, no.2 from top to bottom and the door lock light is separate.
    #252001
    hotpnt
    hi, think you need to check which ones are flashing, the anti-crease is the 1st one (left to right) and wash is again the first one (top to bottom)but this is not a listed fault code
    However if you find that it is the anti-crease and Rinse (2nd down) flashing that would be a pressure switch not sensing fault, (p/sw, wiring or module)
    #252002
    nelson
    Thanks I’ll check it my self tomorrow 🙂
    #252003
    Micky 32
    i recently went to a WF hotpoint with the “pressure switch not sensing” fault code and doing the exact same symptoms. It was the computer that was faulty. 😡
