Re: indesit wia101 spin problem
The electronics on these are known to be a source of constant problems and if the main pcb is at fault it is not really worth changing.
If you have a meggar or suitable multimeter then it may be worth testing all components, especially the heater and motor for insulation faults, check all the wiring connections and make sure the pump filter is clean. Be sure to remove the mains plug first of course.
It depends on your budget, but if you intend to spend £300 or less then don’t expect it to last very long.
