Indesit WIA101UK
  • #32144
    dena89
    Anyone know how to cancel the prog on these? As following the manual never seems to work?
    Also anyone know the part number for the programmed eeprom?
    Its getting harder out there folks!
    #233801
    In order to cancel any program you should turn program knob to 12’th hour position… If it does not reset search for “WIA” threats and will find solution for that… (two choices: wash with alcohol variable resistor of program selector or change it with temperature/spinning selector if it’s available there…)
    #233802
    helo_75
    turn the dial to the off position, thats how its supposed to work!!
    faulty eeprom, as u say
    but, since it wont fit yer original board cos its bigger, youll have to fit a pcb too
    yer right, jobs getting impossible
    #233803
    dena89
    Re: Indesit WIA101UK
    cheers folks
    swop controls huh
    does that mean it will work but boil everything?
    Happy Daze
    #233804
    No, it doesn’t reset because on 12th position potentiometer shouldn’t measure anything but because of dirty (carbon deposits) under voltage will give some readings (not constant infinty)… instead of this it will give corect resistance in other positions… so it doesn’t boil…
