**Indesit WIA111*
  • #62359
    colly
    Any idears on how to read later indesit flashing LEDs ?
    Ind wia111 , machine working perfect but at end of cycle cannot turn machine off at the on/off button,also all LEDs illuminate together then door lock led flashes for times then back to all LEDs lighting up.
    Cheers col
    #349817
    don
    Re: Indesit WIA111
    Hi Col
    Moved this to Trade tech enquiries 😉
    Don
    #349818
    colly
    Re: **Indesit WIA111*
    Hi don
    Thank you so much
    Colin
    #349819
    Its not an error code so it can only really be a PCB failure.
    Always a good idea to megger the heater and motor whenever you get a strange fault and check the connections between the boards.
    EMW are the best option if there is nothing obvious.
    I think that’s a “low end” model with the single board behind the fascia. I think they are the ones which are so unreliable that they caused EMW to reduce their guarantee period to six months.
    Umm Just a second thought on that – wonder if they have a medium sized capacitor somewhere which is under rated – this sounds remarkably similar to the Hotpoint 680uf 10v scenario.
    See, “simple pcb repairs” sticky post 1.
    Mike.
    #349821
    colly
    Hi mike
    Checked the capacitors already, thought that was what i would be going to change.
    However lights are flashing in a controlled manner unlike when the capacitor fault is apparent.
    Also the machine appears to be working perfectly .
    At end of cycle interlock will release in the normal manner,however you are unable to turn machine of at the on off button on the front of the machine .
    Cheers anyway for your input
    colin.
    #349822
    Almost certainly a duff PCB. 😥
    #349823
    colly
    iadom wrote:Almost certainly a duff PCB. 😥
    yes i do think that is the case also.
    seems to have been a circuit board kind of a week
    Cheers
    Colin
    #349824
    A machine like that one isn’t worth spending much money on. I’d advise the customer to use it with a plug in timeswitch so the power is cut off automatically after an appropriate period.
    Mike.
    #349825
    colly
    Hi mike
    Totally agree with you !
    However plug is behind machine and no switch above the bench.
    As for not worth repairing it this guy wants it done.
    Checked on masterpart last night board £46 plus vat so not too bad.
    Colin
    #349826
    Colin
    Pre-programmed?
    Mike.
    #349827
    colly
    Not sure it does not say .
    Ishall ring next week and ask prior to me ordering it.
    Colin
    #349828
    colly
    Checked that board out with masterpart but not pre programmed
    Doh !!!!!
    #349829
    colly
    Hi guys
    I went back to this machine today and fitted a new circuit board.
    I was delighted when i could see the machine now working ok.
    I was talking to a hotpoint engineer who advised me that this is a very common fault.
    I also observed that this machine seemed to be stuck on the one programme, and could not reset.
    It would however complete the programme perfectly ok.
    Cheers
    Colin 8)
