indesit wia111 only fills
  • #36358
    edthespiv
    i tried to reset this machine. No matter which programme i select ( drain, spin) the water valves switch on. I have unplugged w/m and reset, the green led just flahes for ever so i dont know which fault it is. Any help would be great or should i tell customer go to indesit.
    #250742
    helo_75
    board and eprom, naturally
    they just dont reset, regardless of what you do to it
    #250743
    edthespiv
    Re: indesit wia111 only fills
    thanks for your help i will walk away with the call charge
    #250744
    robbo1973
    i have had tonnes of these repaired by emw canny job only takes 5 mins to refit pcb
