I have an Indesit WIA111 in the workshop, I started it on a cycle, it took the water in and started to go around, then I pressed cancel, it stopped. I then tried to pump out the water so I put it on the pump program and pressed start, it carried on with the previous program. I moved it to off and press cancel, then tried again and it carried on again.
Is this a board faulty? I know the pump works as before I tried the cycle I tested the spin and pump options.
