indesit WIA111(uk) cannot reset program?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries indesit WIA111(uk) cannot reset program?
  • #53897
    bigchrisoioi
    help please if you can ,
    have an Indesit W1A111(uk) 4642740000 serial no 608310494 …
    the customer reported that it blew the inlet hose twice after replacement ( 1.5 bar rated hoses).!….when i attended machine it was full of water.
    I cannot reset program, switching it off does not work or does turning the dial to the top off position!..i have tried to hold down the start/pause button to attempt to reset program but still does not move off its program and is stuck on the wash light and program.
    Insulation is 12.6 megs
    Checked manual, it indicates to turn dial to off postion to reset.
    AM I DOING SOMETHING WRONG?..or is it as i suspect a fault on the PCB
    thanks Chris
    #317618
    ray.t
    Re: indesit WIA111(uk) cannot reset program?
    I have one the same mate. Emw list it as a common pcb fault
    Ray
    #317619
    bigchrisoioi
    cheers m8……do you know if they are avaliable configured , or do i need the dreaded software only avaliable to indesit engineers?
    #317620
    funkyboogy
    you can purchase a card reader/programmer from connect etc ..
    it plugs into new module > then you insert smart card which is supposed to prog new module .. smart card is a one shot so if pcb doesnt prog for some reason … its another new smart card …
    what a total rip……
    think ive read somewhere that emw do configured pcb,s …
    ally
    #317621
    allan73
    I puchased a smart card reader, before i found out EMW do them ready configured…….
    So far havent used the reader! 😉
    #317622
    helo_75
    funkyboogy wrote:you can purchase a card reader/programmer from connect etc ..
    what a total rip……
    ally
    unfortuntely, a smart card reader isnt enough to reprogram these
    u need a low end adapter with it
    however that pcb does still have an available eprom, it still doesnt come with one
    emw is the best option, every time
    #317623
    bigchrisoioi
    sorry for my ignorance ..what is EMW…?
    #317624
    http://www.emwelec.co.uk/
    #317625
    bigchrisoioi
    nice one..thanks for all your help guys
