Hi, the inlet valve has 2 white and 2 blue wires which ive traced to a connection block near the main board,but cannot for the life of me find where it connects too, any ideas anyone.thanx
Can’t really give you specific wiring advice however if you follow the solenoid wires you’re referring to they terminate at a multi plug edge connector on the main PCB without seeing the appliance I cant obviously say if there’s a short or a break or poor termination etc if you suspect a wiring fault you really should give an engineer a bell to make sure you get continued, safe , use of your appliance
